What spring.
Old Jul 29, 2017 | 08:19 AM
Gorts 5th's Avatar
Smile What spring.radiator hose.
Good day all.
So check it out i decided to replace my lower radiator hose....thinking its the issue with a hot running motor.
Especially when a/c running.
Now. i feel this is the reason because there is no spring in the hose. And its collapsing restricting flow.
With all that being typed.
The new replacement has NO. spring....unless i purchas the flex hose....which by the way is way more solid than the molded.
So it was my understsnding that all lower hoses had a spring in them.
Sooo. What's what?
Old Jul 29, 2017 | 01:32 PM
AS far as I know... You got it rite.... I Agree....
Unless you buy a spring to install in the lower hose. Your kind of limited to to the Flex stiff hose...
Old Jul 30, 2017 | 02:35 PM
Gorts 5th's Avatar
Smile
Ok good news....
Looks like that was the trick.....after she sucked All the coolant she could possibly take. She's running at 150. Its 80* 98% humidity and running at 150* with a/c.
Unless my tep gauge just took a dump "i kept taping it "
Seems shes getting all the circulation of coolant with that new hose with a spring. This is the first that this has happened to me.
What about other's.have you gotton lower hose without a spring.?
Old Jul 30, 2017 | 03:47 PM
Freting over **** that don't matter, FOSTDM, I haven't used a lower rad hose that had a spring in years. Really!
Old Jul 30, 2017 | 08:42 PM
Gorts 5th's Avatar
I hear it gets reall hot there.
xjonathanx
Jan 30, 2010 09:36 AM
Muswagon
Nov 18, 2009 07:47 AM
Moparknighthawk
Jun 5, 2009 06:42 AM
68 Sat
Mar 16, 2009 07:00 PM
afastcar
Dec 18, 2008 04:15 PM
