what is this sqealing sound
Old Aug 3, 2012 | 12:06 PM
dodgenut7's Avatar
Ok I have a mildly built 340 4 speed when in nuetral and I rev it up I get a sqealing sound and when I wind it out alittle at a higher rpm I get the sound in all gears and I am not close to redlining it driving normal there is no sqeal and runs great so what could this be
Old Aug 3, 2012 | 05:06 PM
70Coronet's Avatar
This might be the obvious but it could be as simple as just a belt squeal, it is common to only show up under load or when the motor is revving quickly as that is when the most stress is put on it, I would swap on a new belt(or both) before going any further-if that doesnt fix it try to get a video of the noise or give more info-good luck!
Old Aug 3, 2012 | 08:26 PM
Turn headlights and fan motor on to see if a load on the altenator changes the noise.
Old Aug 4, 2012 | 03:23 AM
dodgenut7's Avatar
Sorry forgot to say in first post already changed belt that was my first idea. No change with lights on fan on high plus added radio on still squeals. Thanx to both of you for your ideas anymore ideas would be great!
Old Aug 4, 2012 | 05:08 AM
Next thing to try is without the belt for a short time to eliminate alt and water pump bearings as the source.
Old Aug 4, 2012 | 12:38 PM
lou3500's Avatar
Throwout bearing?
Old Aug 17, 2012 | 07:32 AM
Gorts 5th's Avatar
Smile
i had a similar issue
it turned out to be the carb gasket the bolts wer tight but the gasket wasn't sealing the carb and the air being drawn through was making a horrible squeal just as yours symptoms if the gasket is old maybe replace it might be your issue hope this info isn't to old to help
Old Aug 17, 2012 | 11:35 AM
MrOldart2U's Avatar
Originally Posted by lou3500
Throwout bearing?
THAT was my first thought after i read the first post. Does it quit when you push in the clutch or change pitch? May not have enough 'free play' in the adjustments.
Old Aug 17, 2012 | 08:19 PM
challenger's Avatar
pilot bearing perhaps along with throwout bearing
Old Aug 19, 2012 | 09:47 PM
1sttvbn's Avatar
Make sure ALL your pulleys LINE UP. I had the same problem, my alternator pulley was off a little bit (behind the crank pulley). Fixed it with a couple of washers, (3/32).
Old Aug 21, 2012 | 04:00 PM
Gorts 5th's Avatar
Smile
any luck yet
timmie124
Sep 9, 2010 08:21 AM
Moparknighthawk
May 22, 2010 09:10 PM
Barfly
May 17, 2010 08:45 PM
CantRamItDodgeIt91
Nov 3, 2009 09:25 PM
Yorkie Mama
Apr 7, 2008 11:33 AM
