was wondering if you have a tips
Besides 60 over and a mild cam, what else have you done and added to the motor? Do you want more power to light up the tires? To go faster? Depending on why you want more power, you don't always have to do things with the motor.
Guest
Posts: n/a
Headers, duel exhaust, after market manifold can help. electronic ign. a lower gear ratio will help for smoking the tires. i had bigger valves and hardened seats put in that was around 350 for the set, tell us a bit more of the car/truck what you have done to it?
1972 plymouth satellite 440 .60 over 727 trans dana 60 electronic ign is has a 780 holly i think maybe 750 it has dual exhaust......it some times i wounldnt say dies but it kinda stumbles to go if im trying to light the tires.... ......the reason i want to pick up a couple ponies is i did a competition through FORD(sux) they are going to cut me a check for a 1000 dollars and i am buying a few thing like rotors shocks sending unit and gauge set...and what ever i have left over with i believe will be about 206 ish in
so i figured why not try to get a lil more power ......so juts trying to find a cheap way to get some ponies so trell me what you think is a good buy thanks mopar nate
a posi unit in the rear axle will help you to accelerate faster. 66 pretty much hit it on the head with the intake manifold, dual exhaust (with x-over pipe), headers, lower ratio in the rear axle (that could hurt your top end speed though). A shift kit will help to ferm up your shifts and make them a little quicker. A well built tranny will help to get more power to the wheels.
Since you only have about $200 left over, I'd look into an intake manifold or put it towards a good set of headers.
i have 2 or 2 1/2 inch exhaust pipes. so just manifold (i have afteramrket already ??) i have a posi .....and thanks for all your hep just have a lot of money to re think on spending lol thanks guys
put a 1" carb riser under the carb and you will get a few more ponnies and try a good breather (air cleaner) , run a little higher octane fuel as sometimes it does help but not all the time , light weight starter, port and polish the heads you have, trans shift kit, get a electric fuel pump, put the gap to .040 on the plugs use solid core wires aluminum water pump and housing, a bracket torque converter, there are a lot of little things you can do to improve your engine but it all depends on how far you want to go
How long have you been beating on the posi unit? You might want to pick up the back end and make sure that it is still tight. A K&N Stub Stak will help that 780 holley get some air into the motor.
I do actually. I run one on my j10 in an Edlebrock 600 carb. It does help get some extra air in there for a little more power over the whole RPM band. Just make sure that you use the right size air filter with it to really make it work for you. I have a height restriction on my motor so I got an air filter lid to compensate for the lose of height. I love it.
Cheap hp is a borrowed die grinder some burrs that you can pick up at Napa and if you're not experienced do the exhaust side of your heads and match the ports to the exhaust gasket, check swap meets/ scrap yards for headers, it's time to get resourceful. You'd be surprised how many ponies you can find for basically free. Let us know what you're doing and we will try to help.
