k frame
Old May 16, 2011 | 04:05 PM
emmoe's Avatar
k frame
I have a 67 belevedere11 previous owner replaced k frame to put 383 in car my question is there a way to find out what year the k frame is I'm looking to rebuild front end and need to know year ..also about gas mileage what is appropriate mileage for 383 4bl 4sp with a small rear...(approx).
Old May 17, 2011 | 05:53 AM
Bushings are standard sizes, so it shouldn't be a problem. Gas mileage depends on the gear ratio ands your right foot
Old May 17, 2011 | 01:47 PM
MercuryDon's Avatar
Carb jetting and condition will also have an affect on milage. Also Double Pumper Holleys are very thirsty so don't go that route if MPH is important to you.
Old May 17, 2011 | 03:38 PM
what do you mean by small rear? 2.75?
Old May 17, 2011 | 06:10 PM
Your car has an 8 3/4 differential. It could have 2.91,3.23, 3.55 unlikely - gear ratio
2.91 will give the best fuel mileage. Look to see if there is a metal tag under one of the bolts the original ratio will be stamped in it..
Old May 18, 2011 | 03:49 PM
emmoe's Avatar
Rear I believe is 2.90 carb is a vacumn secondary holley....I don't even think I'm getting 1 mile a gallon .mechanic just changed sparks plugs and mileage is still poor..this mpg is normal driving...
TwistedWrenches
May 19, 2009 03:58 PM
adamsb52
Mar 22, 2009 02:24 PM
unruler
Feb 15, 2009 06:14 AM
blue 68 gts
Jan 1, 2009 11:03 AM
smackhonda
Nov 23, 2008 03:38 PM
