Need 2001 Ram 1500 4x4 Stub Shaft
Anyone know where I can get a replacement stub shaft and castellated nut for a 2001 Ram 1500 4x4 with a Dana 60 front axle? I had to heat the original to get it apart and want to replace it with something that still has the temper in the metal. The OEM part numbers are:
Stub Shaft 05015138AA
Axle Hub Nut 04746773
I'd also like to try to find the bolts for the bearing hub. The part numbers for those is 04746775
Thanks,
Tim
Thanks,
Tim
chuckorr
02-07-2014 05:20 AM
