1968 chrysler newport sedan land yaught
Old Mar 4, 2009 | 02:05 PM
it probably has a torqueflite trans
it could just be bad gaskets leaking
Old Mar 4, 2009 | 07:37 PM
theomahamoparguy's Avatar
Believe it or not check the oil dipstick first. make sure the oil looks like oil and not like coffee with cream in it, that would be bad [indicates a blown head gaket]. Ya might
have popped a freeze plug though; hopefully thats it. [Worst case: cracked block.] If oil looks good [...after it warms up outside...], pour water in her and start the engine [keep extra water handy...5 gal bucket....to pour in rad.] keep the rad-cap off and keep mind of water level while its warming up. If the water is gushing from side of engine, dont go any farther, you may be able to see the water [use a small mirror taped to a coat hanger wire]. The freeze plugs are in the side of the block, they're round, shallow cup-shapped deals that plug up round holes in the block. They can rust or; sometimes they pop out when the water freezes in the block. Hopefully this is what has happened. If the side of the block has cracked, you should be able to see that also. The water will be seeping or trickling out of a crack. If the block is cracked, find another engine. The 383 is not too hard to find, Chrysler Corp made about 3 million of them {no kiddin' !} Hey this is just my opinion but hope it helps. GOOD LUCK!!! {'68 newports are sweet rides, thats for sure}
Old Mar 6, 2009 | 03:25 PM
challenger's Avatar
Welcome and do you have any pic's of her we can see and hopefully its just a poped freeze plug and nothing else , does it look like it is coming from under the exh: manifold and can you put water in it and it gushes or just drools out ??
Old Mar 10, 2009 | 03:09 PM
joe440's Avatar
nice buy, i just saw this and laughed cause im going to look at a 68 newport 383 saturday for a summer DD. good luck with everything and lets see some pics!
miatasportscar
Dec 29, 2013 07:39 PM
douglas340
Feb 28, 2011 04:04 PM
mystarcollectorcar.com
Feb 7, 2011 03:17 PM
sgnrulz
Jan 17, 2010 10:15 AM
66sportfury
Mar 13, 2009 02:47 PM
