Dad's 69 Dart 440 4 speed
Old Jan 12, 2011 | 11:37 AM
69eliminator's Avatar
Old Jan 12, 2011 | 03:41 PM
looks real nice
do you know any stats on the car? motor hp?
Old Jan 12, 2011 | 07:56 PM
We have never had it on a dyno, but it runs pretty good. It is 440 six pack rods and pistons, edelbrock performer aluminum heads, mopar purple camshaft, Harland Sharp roller rockers. I am getting ready to build a 500+ inch stroker for it. We have a problem with the 440 that we can't get to stop. It builds pressure in the cooling system and pushes the coolant out the overflow. We have tried everything. Changed to an electric water pump, had the heads milled, new head gaskets, and other stuff I can't remember. The only thing left we can think of is a crack in a cylinder wall.
Old Jan 13, 2011 | 02:28 AM
Thumbs up
Very nice!
Old Jan 13, 2011 | 12:51 PM
challenger's Avatar
Thats a fine looking Dart , have you tried a compression check on the 440 it would tell you if there might be a crack in the cylinder
Old Jan 19, 2011 | 04:04 AM
Mistermopar's Avatar
Originally Posted by 69eliminator
edelbrock performer "aluminum" heads,
Are you using tap water? If you are this could be the problem.
So your cooling system won't depressurize or over flows because the minerals in the tap water ( copper, iron, etc. and even salts) can cause aluminum corrosion. Hydrogen is generated by the corrosion of aluminum at extreme pH levels ( acid or base conditions).
Use only distilled water. You should flush the system very well with distilled water first. Use only a good quality anti-freeze and a small bottle of anti-rust.
Hope this helps, that is if you were using tap water.
Randy
Old Jan 19, 2011 | 04:18 AM
Randy
Randy - Great advise. I never thought about that with tap water but it does make sence.
Old Jan 19, 2011 | 04:25 AM
Thanks!
I think I once read about it in a Mopar mag. Then I was having some problems with my car, I have an aluminum rad. Things got much better when I stopped using tap water.
Randy
Old Jan 19, 2011 | 07:50 AM
rexus31's Avatar
More pics!
Old Jan 19, 2011 | 03:31 PM
Originally Posted by rexus31
More pics!
2x on that!
Old Jan 19, 2011 | 04:03 PM
Silverick's Avatar
Nice car!!
Old Jan 19, 2011 | 04:37 PM
maddawg57's Avatar
Nice ride I always had a thing for darts.
jf5555
Apr 9, 2011 04:10 PM
peteysdart
Jan 10, 2011 08:23 PM
blue 68 gts
Jul 24, 2010 06:22 AM
MReeves
Stock Eliminator
Jan 3, 2010 07:21 AM
bstiles88
Aug 6, 2009 06:02 PM
