hi need help
Old Dec 16, 2019 | 04:41 PM
nounouram's Avatar
hi need help
just rebuild dodge ram 318 1983 engine it starts then dies put with gas it dosnt what can be the problem
Old Dec 17, 2019 | 09:29 AM
Mopar of the month, huh? Odd place to post.
We would need to know more about what is happening. Full words are great, too.
Old Mar 5, 2021 | 06:01 PM
Yes full sentences help, we can only guess what you're after.
Old Jun 20, 2021 | 01:43 PM
Cicholski440's Avatar
Check your timing (make sure spark plug wires are set for correct firing order, in the correct spot on distributor cap and cylinder.)
Old Jul 29, 2022 | 06:10 AM
Ghostrider 67's Avatar
Looks like you're saying it dies unless you pour gasoline into the carb to keep it running? Then if that IS the case you have a fuel delivery issue. The pump, or electric pump if you have one, isn't working for some reason. Is there actual gas in the tank?
osok6
Aug 8, 2018 06:56 PM
allengreen
Oct 17, 2014 08:34 AM
Jayman55
Jun 7, 2012 11:13 AM
gotdust
Sep 30, 2010 06:04 AM
FryGuy
May 24, 2008 12:36 AM
