'73 Satellite Custom Wagon
Old Sep 17, 2012 | 08:02 PM
heyhoody's Avatar
The standard tire is 215/75-R14, and I can only find a Hankook Optima in that size (they're on it now, and not so great). I found trailer tires at tirerack, and it fits the description for what I want (durable, higher inflation, ect). It also says "not for passenger vehicles". Can anyone give me a good reason why I shouldn't get trailer tires for my '73 Satellite wagon? Thanks
Old Sep 17, 2012 | 08:18 PM
YOU do not want trailer tires !!!! Standard size 205/75/14 . You might look for a 70 series tire 205/70/r14 or even a 215/70/r14. / G70/14 I have an Olds has 13" tires getting hard to find too..
I would go with http://www.tirerack.com/tires/tires....omCompare1=yes
Old Sep 17, 2012 | 08:42 PM
heyhoody's Avatar
Thanks -- that helps. If possible, I want a tire that'll give it a little more ground clearance (if possible). With people in the 3rd seat, it sits really, really low.
Old Sep 17, 2012 | 10:23 PM
On a wagon I would bet you could put a 225/70/14 on it without any problem if you wanted it higher
Old Sep 23, 2012 | 09:09 AM
heyhoody's Avatar
thanks again...
So, if there appears to be plenty of clearance in the wheel well for a bigger tire, then can I safely assume a bigger tire will be OK? You had said that a 205 is standard, and I've got a 215 on there now with lots of room (see attached pic). I think I'll go with the 225.
Thanks again -- I know next to zilch about this stuff ...
Attached Thumbnails '73 Satellite Custom Wagon-wheel-well-1973-plymouth-satellite.jpg
Nshorosh
Apr 19, 2012 06:55 PM
heyhoody
Dec 26, 2011 10:08 PM
heyhoody
Dec 26, 2011 07:25 PM
shorosh
Jul 30, 2011 09:42 PM
73SatWag
Dec 14, 2009 01:55 PM
