Anyone using 16's or 17"s
Old Oct 27, 2011 | 10:14 AM
JS23's Avatar
What sizes are you using and what size wheels?
I put 17"s on my Challenger 225/50R17 and 255/45R17
wheels are 17x7 and 17x8
Now I'm considering 16"s on my 68 Chrysler 300
Old Oct 28, 2011 | 06:21 AM
powerman3's Avatar
Wheels & Tires
I'm restoring a nice 1967 Plymouth Barracuda, have changed 14" Drums (non power) front and rear with the new (power) SSBC disc 11" 5x4.5 Front and 10" 5X4.5 rear. I had to change axels and now I'm facing the problem of size for new wheels and tires, no one seems to know what size wheels to use. I would like to use American Racing Chrome but I need the proper size with or with out offset. Someone please help!!!!!!!!!!
THANK YOU
Old Nov 5, 2011 | 07:43 AM
JS23's Avatar
I restored a 67 barracuda and put 225/60R14 on.
Wasnt terribly happy with the look.
The width was good but the overall diameter seemed a little short.
Unless you are lowering the car I would suggest getting a tire around 25" in O.D.
Check a 225/45R17
There are some great Summer only performance tires available in this size.
My personal favorite the Dunlop z-1 star spec. Unreal grip.
Old Nov 6, 2011 | 06:59 PM
Dreber12xes's Avatar
Tire size??
I am restoring my 77 Plymouth Volare Roadrunner and I am planning on getting a set of 16" Cragar Keystone Klassics as these are the same wheels I had on it back in 1977. It came with E70 15" Good Year tires. What size tires can I get that will fit this car and these rims?
Old Nov 6, 2011 | 09:32 PM
Silverick's Avatar
I have copied a link for tire size comparison....
The tire sizes from back in the day should translate as follows:
H = 225
G = 215
F = 205
E = 195... if it follows the pattern....
So, your original E70/15 would translate to a 195/70/15.
I am just thinking off the top of my head but, I think that I am correct.... or close to correct.
http://www.1010tires.com/tiresizecalculator.asp
Good luck.
Rick
Old Nov 7, 2011 | 08:39 AM
Thanks for the feeback and the link.
Old Nov 7, 2011 | 03:19 PM
This may help: http://www.rimsntires.com/specs.jsp
Old Nov 7, 2011 | 06:21 PM
Silverick's Avatar
I've seen this before but, never played with it......
I've been playing for about 1/2 an hour!
They even show that a 17" x 8" wheel will go onto my '68 Fury...
Old Dec 21, 2011 | 07:35 AM
JS23's Avatar
Be careful with 8" wide wheels in the front. It may require you to adjust the torsion bars to to get the proper clearance. Or a fender lip roll.
Problem can occur while at full lock turn and some compression to the suspension.
69POLARA383
Feb 22, 2012 05:54 PM
69POLARA383
17
Dec 20, 2011 09:31 AM
bremereric
May 20, 2011 06:15 PM
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
Commando
Oct 16, 2008 09:23 PM
