dodge truck 20 inch aluminum rims leaking
Old Nov 15, 2011 | 10:50 AM
marvgreen's Avatar
anybody have this trouble, my 04 1500 dodge pickup wheels
leak air. i believe it is caused by the clear coat they put on
them and it is coming loose and causing leaks. all four tires.
can these be buffed without causing them to carrode and
still leak.
on a limited budjet so i can't afford new rims
Old Nov 15, 2011 | 01:03 PM
You need to dismount the tires and remove the clear from the tire bead area You could do it with some wet & dry sandpaper. A 3M fiber disk on a die grinder, a sanding flapper wheel, lots of ways. It is a matter of getting the bead clean.
Old Dec 21, 2011 | 07:58 AM
JS23's Avatar
Are your wheels chrome plated?
72demon440
Sep 13, 2013 04:32 PM
63DARTGT
Dec 13, 2008 05:34 PM
63DARTGT
Dec 8, 2008 11:15 AM
63DARTGT
Dec 4, 2008 06:48 PM
shadowwolf30
Cuda Specific Discussion
Oct 31, 2007 12:55 PM
