Drag tires for Duster
Old Dec 4, 2011 | 03:55 PM
Duster 340's Avatar
Here is my dilemma, i dont know what size or where to get those i guess new or not treaded what would be slicks. Here is Hoosiers, there called "Pro Street". http://www.hoosiertire.com/strttire.htm And i check Hoosier and Tire Rack.com and other places and for a 70 or 71 Duster they only have Cuda. And i am not sure how the size works either. Bremereric said i can get rims for the tires so i dont have to change the axle and where can i get them to or the tires to fit the wheel space.
Old Dec 4, 2011 | 04:07 PM
If your tire space is like my Dart then the biggest street/slick will be a P245/60/15 back there without some of that mini-tubbing.
Old Dec 4, 2011 | 06:48 PM
I would suggest taking a wheel off and use a long straight edge on the drum face and measure to the outside then inside, take off 3/4" and use this program to figure wheel offset: http://www.rimsntires.com/specs.jsp
Old Dec 4, 2011 | 07:59 PM
That's a good resource 500...you know what will make you made...I got some 15 X 8 with 4.50" backspacing wheel on the rear of the Aspen with some P275/60/15 tires. I could probably put some P295/60/15 with no problems. It makes me sick when I look at my Dart's puny tires.
Old Dec 4, 2011 | 09:04 PM
dusterboy89's Avatar
i got a 72 duster and someone told me i could fit a 15x10 rim on the back is this true by any chance and what back spacing would i need
Old Dec 5, 2011 | 01:43 PM
Duster 340's Avatar
Bremereric, where can i get such tires or similar? I check Tire Rack as said above and the North East Hoosier tire distribution may have them.
Old Dec 5, 2011 | 02:27 PM
Look for some Micky Thompson ET street radials. They can be had all over the place. You can also try Nitto Tires.
http://www.nittotire.com/Tire/nt555r
Old Dec 21, 2011 | 08:13 AM
JS23's Avatar
call Ethan. He knows about classic Mopar
check this link
How to measure for tire fitment
bully62
Sep 14, 2014 12:55 PM
dpmalibu
Mar 21, 2013 01:15 PM
Franco
Oct 27, 2012 09:46 AM
siliconcrunch
Apr 5, 2008 06:04 PM
mcwulf30
Apr 25, 2007 02:38 AM
