1967 GTX carb questions - Help!
Old Jul 10, 2010 | 07:22 AM
Ellis Wyatt's Avatar
So I've done a lot of fruitless research trying to determine which carb fits my GTX. The two carbs that I have are pictured below. The one with the red tag reads "322 4326S" and the one with the silver tag reads "4327S". My car is a 440 HP with a standard transmission.
I need to know which carb is the right one for my car. The extra linkage on the right side of the 4326 makes me think it's for an auto trans, but what I've read online saus its for the standard. The 4327 has thrown me completely.
Also, is there a company out there that can do a complete restro on the carb (looks-wise to bring it back to the factory "shine")?
Thanks in advance guys!
Old Jul 10, 2010 | 08:38 AM
is there a difference in cfm's between the two?
Old Jul 10, 2010 | 02:36 PM
Honestly, I think they're both 750 cfm carbs. The only difference I can see between them is that the 4326 has extra linkage on one side, and the 4327 has some sort of module on the left side of it that I have no idea what it is.
Old Jul 10, 2010 | 06:04 PM
1966sportfury's Avatar
A.K.A Bob Dodge
that module disengages the high idle, they both are 750 cfm, other than that i cant tell u much else
the 4327 was the hp carb
Old Jul 10, 2010 | 06:39 PM
Thanks Fury. I have read that the 4327 was the right carb for the HP motor. but I have no idea what to do because of the extra linkage on the side...
Old Jul 11, 2010 | 02:36 PM
well, for a 67 gtx with a 440, the original carb. is an 800 cfm
Old Jul 11, 2010 | 07:58 PM
Carter or Holley 800 CFM?
Old Jul 11, 2010 | 09:18 PM
A.K.A Bob Dodge
80% were
the extra linkage is detachable, so couldnt you just pull it off?
Old Jul 12, 2010 | 10:27 AM
carter
Old Jul 17, 2010 | 06:33 AM
Well, because of all the confusion over the carb, does anyone have any exp. with the Edelbrock Performer 800 CFM with the electric choke?
Any forseeable problems I'd run into with using this carb on the car?
Old Jul 17, 2010 | 08:13 AM
I just got the thunder series 800 cfm
Old Jul 17, 2010 | 09:54 AM
A.K.A Bob Dodge
no you should have no problem with the carb at all,
Old Jul 17, 2010 | 11:08 AM
Barfly's Avatar
Here is a Carter Carburetor Selection guide for different cid engines.
Joe.
Old Jul 17, 2010 | 11:45 AM
A.K.A Bob Dodge
or you can just take the cid times it by rpm limit and devide by 3456
440x5000rpm /3456= 636.5 so you would round up to 650
Old Jul 22, 2010 | 02:58 PM
Hey, thanks for all the help so far guys. I've decided to just use the 750 CFM for now to get the car running. First firing (since 1979) should be this week coming up, so wish me luck! I'm going to save up until I can afford either an old Carter Performer 800 or Edelbrock 800.
Oh, and for your viewing pleasure...
Old Jul 22, 2010 | 04:34 PM
A.K.A Bob Dodge
sweet! let us know how it runs,
Old Jul 23, 2010 | 08:04 PM
looks good
koondawg_74 roadrunner
Oct 19, 2011 08:39 AM
1967gtx
Sep 16, 2011 09:54 PM
hellbndr23
Feb 4, 2009 08:04 PM
El Destructo Inc
Jul 29, 2008 07:36 PM
34 Chrysler
Jul 8, 2008 03:02 AM
