1973 440/ 4 speed question
Old Aug 27, 2010 | 03:05 PM
robocop1971's Avatar
i bought a 73 440 truck engine with a steel crank it currently has the automatic trans behind it. I plan on rebuilding the engine and buying a 4 speed to replace the automatic trans, is there a specific year 4 speed i have to use as well can i use a 23 spline behind it? Any info would be greatly appreciated! When i go to build the motor i'm looking to get around 450 hp on the rebuild. I have no direction yet on how i want to go on rebuild; im in process of gathering parts and saving money.
thanks,
Old Aug 27, 2010 | 03:50 PM
1966sportfury's Avatar
A.K.A Bob Dodge
any year will work just need a BB bell housing and a manual crank, or cut down the input shaft of the 4 speed to fit in the automatic crank.
Old Aug 27, 2010 | 07:45 PM
So can i get by with a 23 spline or am i looking at the more expensive 18 spline tranny for this 440?
Are the 902 heads worth rebuilding to get better compression or should i look for some other heads for the rebuild?
Thanks for the help!
Old Aug 28, 2010 | 02:42 AM
A.K.A Bob Dodge
the 23 spline will handle 500 hp easy,
44070dart
May 30, 2015 07:34 AM
lgad
Feb 6, 2012 04:14 PM
70bee
May 30, 2009 11:21 AM
joel
Feb 22, 2009 07:07 PM
makemineduster
Oct 14, 2008 04:27 PM
