2004 ram 1500 limp mode
Old Dec 21, 2022 | 01:23 PM
Aedan's Avatar
I have a 2004 ram 1500 4x4 automatic it’s in limp mode with the flashing lightning bolt on the dash but it has no engine light or codes and I have already replaced the throttle body. Does anyone have and reason why this could be happening?
Old Dec 21, 2022 | 02:38 PM
The place I would start is looking at all electrical connections including all grounds. One bad ground Can generate chaos in your modern electrical system.
Old Dec 21, 2022 | 02:44 PM
Aedan's Avatar
They seem to be fine but I will go back through take them off and clean them all up
Old Dec 21, 2022 | 06:16 PM
Aedan's Avatar
That did not fix my problem is there any way it could be a dead pcm?
Old Dec 21, 2022 | 06:51 PM
Have you scanned for codes yet?
Old Dec 22, 2022 | 08:37 AM
Aedan's Avatar
Yes I did there were none it had no engine light but I figured it out it was a cut wire going to the TPS it was some how cut back in the harness
Old Dec 22, 2022 | 10:25 AM
Wow, The wire was cut/broken for the TPS? And it didnt set a code?
How did you find it? Did you just notice it on your labscope / Scantool?
Coolguy
Sep 29, 2021 05:46 AM
Mudrunner-08
Mar 24, 2020 05:31 AM
JohnnyL
Mar 1, 2019 12:38 PM
osok6
Aug 8, 2018 06:56 PM
checho
Oct 4, 2011 02:28 AM
