318 magnum convert to carb
Old Sep 11, 2009 | 09:50 AM
craveman's Avatar
Senior Member
i got a great deal on a 318 magnum engine with 54k on it. my cousin wrecked the truck and said i could have it if i wanted. my question is have any of you guys switched this over to carbed intake? also will my mopar electronic ignition work on this engine. also any rough estimates of what this engine would make carbed with the stock cam? and will it bolt to my 904? hopefully it will waken up my fifth ave a little bit. maybe if im lucky i can get a high 15 quarter out of her. thanks
Old Sep 11, 2009 | 11:13 AM
Crazy4Carz.Com's Avatar
Power will not change with a carb over FI. At WOT they are exactly the same. FI gives you better drive-ability and tuneability. Yes it should bolt up to the 904. For HP numbers Google the model and year of the truck and you can get performance numbers.
Old Sep 11, 2009 | 04:32 PM
why would you want to go carb?
Old Sep 11, 2009 | 04:46 PM
HEY!!!!
What is wrong with Carbs?
Old Sep 12, 2009 | 10:39 AM
craveman's Avatar
Senior Member
because carbs are easier for me and i dont have to wire everything up an put a computer in it then. can i use my current distributor and ignition with this engine?
SPICOLIE203
Dec 4, 2013 10:24 PM
johnboy
Feb 1, 2012 11:20 AM
goodfriend
Jun 17, 2008 12:30 PM
goodfriend
May 18, 2008 06:26 PM
GLASSMAN
Jan 8, 2008 01:34 PM
