383 a/c eliminator question HELP!
Old Aug 30, 2010 | 09:07 AM
sixfive407's Avatar
I am trying to eliminate my ac from my 67 383. I have recently purchased a s and j engine and wish to eliminate the ac. I ha\ve been trying to research places to find the right setup without spending 500 for serpentine kit. I have tried bouchillon performance in the past but do not see the eliminator pulley and bracket anymore. Any ideas? Can you buy non ac pulleys or do i need dummy pulley. I am trying to use alternator, water pump, and power steering.
Old Aug 30, 2010 | 10:50 AM
72RDRNR's Avatar
Check out www.440source.com
Old Aug 30, 2010 | 01:35 PM
Silverick's Avatar
I did the same thing, years ago.
You will need the power steering and alternator brackets from a non a/c car and change the 4 belt crank pulley to a 2 belt pulley. Back then, I just went to the wrecking yard and picked the set that I wanted! Not like that now
The alternator, water pump and crank pulley on one belt.
The power steering pump and crank pulley on one belt.
Old Sep 24, 2010 | 04:52 PM
69POLARA383's Avatar
Im doing the same thing, I am pretty sure I found a set on jegs that has just the alt, crank and water pulley, 2 belt crank pulley, fairly cheap by March.
Old Sep 24, 2010 | 05:07 PM
they have the kit with power steering pulley too.
Old Sep 24, 2010 | 05:13 PM
http://www.jegs.com/i/March+Performa...10050/10002/-1
Randy Hutchings
Jun 30, 2011 05:49 AM
MReeves
Stock Eliminator
Apr 19, 2010 01:58 PM
MReeves
Stock Eliminator
Feb 14, 2010 05:23 PM
