383 cam help
Old Jun 23, 2009 | 09:25 PM
scotts74birds's Avatar
Lots of conditional factors here. When you throw in a turbo....everything most of us know goes out the window. The cam tech lines are the best way to go. They have computer programs that can plug in everything. One word of advice, if you are in between cams for selection, get the smaller one. Being over cammed sucks.
Old Jun 24, 2009 | 02:36 AM
Polaradude's Avatar
Yup. x 2 on that.
Old Jun 24, 2009 | 11:19 AM
what is your compression?
if it is too high, you'll melt your pistons with the turbo
Old Jun 24, 2009 | 02:18 PM
supposedly???
no no no
you have to be 100% sure before you turbo or supercharge anything
Old Jun 24, 2009 | 05:16 PM
theomahamoparguy's Avatar
Originally Posted by 919speedychris
He told me that it was. How do I check to make sure?
I would pull the head and take some measurements.
1. top of deck to top of piston at top dead center (deck heigth)
2. Volume of the piston notches ( use a graded burette in cc's){summit}
3. Thickness of the head gasket after compressed
4. Actual cc's of the combustion chamber ( graded burette in cc's)
{these measurements should get you close to accurate}
Then you can "plug" the numbers into a compression ratio calculator on the internet. [wish I had a site handy, east to find though]
A .030 overbore on a 383 comes out to 4.280
B The stroke of the 383 is 3.38. {or very close approx.}
Old Jun 24, 2009 | 06:56 PM
My friend came over and helped with measurements, and it came out to 8.75 to 1. Is this too much for a turbocharger? The turbo is not very big.
To make it a little safer, I'd try a little bit thicker gasket. Other than that, I think you should be just fine. You need to look up some of the turbo sites and find out about "boost referenced timing boxes" these drop the timing off when under boost/load. You dont want to run the thing lean either. That's all I can tell ya about turbos.
[also turbo's like more exhaust duration on the cam;call comp cams info]
Should be interesting though, a 383 with a turbo all in a power wagon, crazy man!
Old Jun 25, 2009 | 05:20 PM
wanna trade for the hemi?
lol
Old Jun 29, 2009 | 12:25 PM
good luck
keep us posted
labradorian70
Sep 24, 2014 09:44 AM
Springerpilot
May 15, 2012 07:03 PM
deadkelly
Mar 13, 2010 06:27 PM
killamachine
Jan 14, 2009 08:49 AM
bcuda65
Apr 26, 2007 04:38 PM
