440 / 727 engine shake.
Old Mar 15, 2008 | 06:32 PM
I'm not familiar with specific numbers, but here's a few rambling thoughts:
Six pack 440's WERE externally balanced. I'm not sure, but I think 400's are.
The point being, be very suspicious of EVERYTHING until you check it out.
I assume this exhibits the problem in neutral, so that you've eliminated drive shaft vibration?
have you troubleshot the problem with the belt(s) disconnected to eliminate them?
If you get "down to it" I'd suspect anything. has the engine been rebuilt, and is it possible that some odd crank/piston combo has been used?
I'm not familiar with how the converters are balanced, but it seems reasonable to suspect that a weight(s) is / are missing
Old Mar 16, 2008 | 09:02 AM
A quick and dirty way to eliminate the engine is to do this:
make sure it is tuned good, running smooth, warmed up good and adjust idle for good smooth idle. If you are running "lots" of advance, temporarily run advance back to no more than 5 or 8 BTC, and set idle for a good smooth idle, maybe 700 or so.
Now, take a test tach that you can REALLY READ with a wide scale, and do a "cylinder balance." simply use a wire to ground each plug at the distributor tower. One way to do this is simply pull the dist. boots, and use a probe between the wire and tower, or (pre) loosen the wires so you can pull one at a time. GROUND the tower as you pull the wire to prevent cross-fireing.
This should show up imbalance.
It might also pay you, before doing radical surgery, to find someone who has a good leak down tester. You can make them, but getting the proper orifice is questionable.
Just Google home made, "leak down tester"
Personally, I would concentrate either on incorrect engine internal parts or the torque converter.
It certainly is possible that exhaust could cause this, especially in these cases where these cars are old and parts have been modified/ changed, etc over the years. If you are using non-standard hangers in the exhaust, I'd take a good look at them.
Old Mar 16, 2008 | 02:00 PM
Good luck. Without being there, you've pretty much exhausted my ideas, and sounds like you are well "dug into" researching the problem.
Old Feb 4, 2009 | 05:17 PM
Seawolf seems to be an "eight post wonder"
i know polaradude will like that one
Old Feb 4, 2009 | 05:53 PM
Polaradude's Avatar
Indeed I do...lol 8PW
Old Oct 6, 2009 | 07:10 AM
Gumby's Avatar
Cool I know this is an old post ...However...
The easy way to resolve that issue, or at least nail it down, had nothing to do with the engine and how it was running. It was all about the Torque converter. He stated in the first post that he had changed the TC. In his second post I think it was, he stated that it didn't match the original, therefore it was NOT going to be balanced the same as it was before. It didn't matter if it was externally or internally balanced, it was now OFF
Here's what I would have done. Since there is no alignment hole to match up to on the flex plate, I would have removed the inspection cover, removed all four of the TC bolts and taken a pen and marked the converter with an arrow to show which way I was going to turn it, and marked the flex plate & converter with a mark to show the original location. Then I would have rotated the converter only (Not letting the flex plate rotate...only the converter) in the direction of the arrow by 90 degrees so the next bolt hole came in to view and lined it up and bolted it to the flex plate with just 2 bolts 180 degrees apart (reduces the work and keep the bolts balanced as well.)
Repeating as necessary until the correct balance position is found. It was VERY possible that he had installed the new TC out of position for THAT new TC. Since it didn't match, it may have needed to be in a different position either 90, 180, or 270 degrees off from the where it was.
That's what I would have done is his position. if NO good balance spot was found, then he needed a different TC.
I'm currently in the process of doing a complete and total tear down and rebuild of a 78 440. It current;y has a cast crank, but I will probably changing that to a Forged and have it all internally balanced utilizing the Professional Products (brand name) Harmonic dampener which comes with weights of you need them, or you run it without weights for internally balanced. At the Machine shop, I'm going to have the entire rotating assembly, Crank, dampener, flex plate and TC balanced with the dummy weights for the rods, pistons, pins and rings on the crank as well. This will be a good true balance. This wasn't an option for this guy. Sadly, he never posted what his final resolution was.
Mopars Live...
Richard
Edward Mayberry
Jan 27, 2015 01:52 PM
SteveRT
Oct 15, 2014 04:24 PM
Doze
Sep 14, 2012 08:32 AM
pipdog69
Mar 13, 2012 11:01 PM
jd.fisher
Mar 25, 2009 06:08 PM
