440 Build, Input?
Old Mar 24, 2010 | 05:17 PM
69Fury3's Avatar
440 Build, Input?
So i am starting my 440 build again. Here is what i have on the list:
Mopar .509 Purple Cam
440 Source Stealth Heads
Edelbrock RPM Intake
Factory Rotating Assembly (1968 Forged) Balanced
Factory Forged Pistons
Shumacher Tri-Y 1-7/8 Headers
Edelbrock 800 CFM Carb
Mopar Electronic Ignition
2 questions.
1. What bearings should i use? I want long life (this will not be a race engine) Full or half groove bearings for mains and rods?
2. Out of curiosity, what kind of horsepower do you think i will get from this combo?
Thanks
Old Mar 24, 2010 | 05:48 PM
scotts74birds's Avatar
It looks like the key to this is to find your Comp ratio. I dont know if the pistons are zero-deck, flat tops, dished, or who knows what. And what is the the cc's of the heads? Cr might be good to know before you start selecting a cam. Bearings? Me, I would go with the standard clevite 77's. go to the Comp Cams website and download their Camquest program. It will let you plug in different components and show a tq and hp graph to let you see how they will affect your set-up. Good luck, Scotty.
Old Mar 24, 2010 | 05:53 PM
69Fury3's Avatar
Stock pistons are flat top. Original heads were the 906 castings with 80cc chambers. The 440 source heads also have 80cc chambers but they are closed chambers. Factory compression ratio i believe was 10.0 : 1 in 1968. Does their program show expected compression ratio after adding a new cam? I want to run on pump gas.
Old Mar 25, 2010 | 01:15 PM
you should be able to run on pump gas
Old Mar 25, 2010 | 06:35 PM
69Fury3's Avatar
I just downloaded the CamQuest program, it is really cool Thanks! I just thought i remembered reading a tech article somewhere on half groove vs. full groove bearings but don't remember where or what it said
Aug 7, 2009 11:21 AM
816allen
Jun 27, 2009 09:29 AM
Polara_68
Jun 13, 2009 11:23 AM
modtop
Apr 8, 2009 06:47 PM
polara68
Oct 13, 2007 09:53 AM
