440 heads
Old Nov 27, 2009 | 10:53 PM
71mopar's Avatar
440 heads
Checked the head #'s on a 1966 440 motor I picked up. The last 3 numbers are 516 Just wanted to know if these are good heads. They should be the original.
Old Nov 28, 2009 | 04:33 AM
Polaradude's Avatar
Are they part#2406516 ?
Old Nov 29, 2009 | 08:31 PM
71mopar's Avatar
head casting number
Yes
Old Nov 29, 2009 | 09:09 PM
theomahamoparguy's Avatar
the 516 heads were closed chamber heads like the 915's but did not flow as well as the 915's of 1967. with some work you can make them work fairly well in a street application. A friend of mine had a set of them on his 70 GTX that worked very well. (11.70's back in the 80's). He used them cause he could not find a set of the 915's and he wanted the 516's for the compression gain. He used a big cam. They were ported and bigger valves were installed.
Old Nov 30, 2009 | 03:00 AM
Polaradude's Avatar
The heads in question were produced from 1964-1967 and they were put on the following engines: 361,383,413,426. These are what was referred to as 300L heads. They came with a 2.08 intake and a 1.88 exhaust valve. They had a chamber of 73.5cc.
Old Dec 2, 2009 | 09:32 AM
ykf7b0's Avatar
Are you sure the exhaust valves are that big? I'm thinking the 516's exhaust was more like 1.60 and the intakes were 2.08 like the 915's. Correct me if I'm wrong.
Old Dec 2, 2009 | 01:21 PM
Polaradude's Avatar
Well I have two references that have two different numbers, 1 is 1.60 and 1 is 1.88
69Fury3
Feb 26, 2012 07:43 PM
getsum
Dec 10, 2009 10:01 AM
Coronet1970RTguy
Nov 29, 2009 05:29 PM
Demented
Jul 23, 2009 03:59 PM
69Fury3
Apr 15, 2009 03:34 PM
