440 Tunnel ram Question
Old Feb 5, 2009 | 03:30 AM
My take on tunnel ram, high riase intakes, etc. is that they make power in the higher RPM range (3500 RPM and up). You can drive it on the street but some aftermarket manufacturors don't recommend it. If its just for the strip, then yeah its a good idea but you will need a cam that will work in the same RPM range and a good set of heads that flow well (a lot of set out there).
t/s1148
Apr 29, 2015 11:09 AM
Scott Moats
Jan 8, 2013 03:15 PM
H-Pattern
Mar 2, 2011 02:58 PM
cliffg50
Dec 17, 2009 02:37 PM
Team Gridlock
Aug 20, 2009 05:19 PM
