‘59 Saratoga left blinker?
Old Nov 15, 2024 | 08:42 PM
samkrobes's Avatar
Hi all
New to the forum, I’m looking for some help with an issue I've been having.
For a while the left blinker worked intermittently, moving the turn signal stock around while in the down (left) position got it going sometimes. Wondering how I can get access to the switch in the column, looks to me like pulling the steering wheel will allow the plastic column cover to slide off? Is there some kind of special wheel puller for these older Mopars at all?
I believe it's the switch, not 100% certain but the right side blinker is now starting to have the same intermittent problem. The bulbs are good, the light on the dash does not light up for the left side which makes me think it is the switch.
Am I right to pull the wheel off??
Thanks
Sam
Old Nov 15, 2024 | 10:44 PM
Welcome to the forum,
I would check the flasher first…
Old Nov 16, 2024 | 05:13 AM
Kuvasz101's Avatar
I agree on checking the flasher too. Those signals don't work well if at all when the car is off. Your question about the wheel puller is yes there is a small puller that screws into the holes on each side of the main steering column nut.
Old Nov 17, 2024 | 06:27 AM
Kuvasz101's Avatar
I previously said they don't work well with the car off. I meant to say with the key on and engine not running the flashers often don't work properly. It's best to have the engine producing power while checking the turn signals. .
Old Nov 17, 2024 | 08:48 PM
samkrobes's Avatar
Much appreciated gentleman 👍
Will check the flasher tomorrow and hope I don't need to pull that wheel... if it's as seized as everything else on the car.
Old Nov 30, 2024 | 10:08 AM
polarmop's Avatar
Yes, you're on the right track!, you'll need to pull the steering wheel to access the turn signal switch. Use a steering wheel puller (commonly required for older Mopars). Once the wheel is off, remove the column cover to inspect and replace the switch
pilotpete
Sep 29, 2019 07:42 AM
SixBanger
Jul 9, 2018 09:06 AM
nicocottone91
Aug 14, 2013 03:12 PM
Leem
Sep 10, 2011 07:02 PM
azzkikr
Feb 21, 2008 04:36 PM
