65 Fuel Pump
Old 04-11-2010 | 07:52 AM
jhart21's Avatar
Junior Member
65 Fuel Pump
Newbie here. I think I've got a fuel pump issue with my New Yorker. I don't seem to be getting fuel from the fuel pump up to the carb. The lines are clear, filter has been replaced, new fuel pump etc. It seems as if the "pushrod" isn't priming the fuel pump. Is there any way to fix this? I can't really tell if the pushrod is moving or not and there's no tool to get in that tight space (that I've found). Help??!! Thanks.
Old 04-11-2010 | 11:09 AM
1966sportfury's Avatar
A.K.A Bob Dodge
one way to tell if the rod is making contac with the fuel pump. is back off the bolt a couple turns and have someone else watch to see if thefuel pump wobbles when the engine is turning over. and if its working but still no fuel. and im asumming there is enough fuel in the tank. you can use a compressor to push fuel thru the tank to the carb.
Old 04-11-2010 | 12:25 PM
toad490's Avatar
The pushrod is probably worn. Try one of those magnetic pickups in the hole. Tape the sides up and leave the end exposed.
Old 04-11-2010 | 05:55 PM
A.K.A Bob Dodge
im sorry this might be a dumb question but why would you want to tape the sides up? i assume you are talking about the magnetic drain plugs correct?
Old 04-12-2010 | 03:44 AM
toad490's Avatar
I was think of something like this.
http://cgi.ebay.ca/Mighty-Worm-26-Fl...item230673af95
I just thought taping the sides would keep it from sticking to the sides of the hole and just make it a little easier.
Old 04-12-2010 | 05:57 PM
A.K.A Bob Dodge
i see why! i understand!
mopars&vampires
06-23-2009 10:31 PM
nailbender
12-06-2008 08:11 PM
nailbender
11-27-2008 10:20 PM
skymynx
10-21-2008 08:15 AM
rapidride2
03-20-2007 06:58 PM
