727 trans question
Guest
Posts: n/a
Start at the front of the transmission, tear it all the way apart to the rear and put in a different tailshaft. The tailshaft is the first piece in to the case. You would be better off the get a drive shaft made with a slip yoke if you want to use this transmission.
