78 D-100 Windshield Wipers Stopped Working
Old Dec 20, 2009 | 09:01 AM
theomahamoparguy's Avatar
the only thing I can think of is that one of the plastic grommets might have broken on your wiper linkage. and for some reason the lack of it has caused a noise while driving. When does it do what you are describing? While driving? While idling? Wipers on? Wipers off? dodge trucks are also notorious for having under the dash wiring problems too, (the gauges especially). Are your gauges working correctly?
Old Dec 21, 2009 | 04:39 PM
I'll bet it is the wiper motor. They can go out just like that. The clicking might br the noise made by the motor short-circuiting. I'm surprised that the fuse has not blown. you could try hot wiring the wiper motor just to see if it makes it work. It might be something to do with the auto-park feature or the low/high speed wiring of the wiper motor. Make sure you have a fuse in your jumper wire. It would be kind of like a bench test of the motor. other than that, I cannot think of any reason it would not work. There are no relays for the wipers that I can think of. (a relay would "click" though) Bad ground? I dunno... good luck.
Lorcinls1
Feb 3, 2014 06:06 PM
josehf34
Jan 2, 2014 04:06 PM
1974moparduster
Nov 2, 2013 10:53 AM
67Polara
Aug 9, 2009 09:02 AM
dnoonkeste
Apr 17, 2009 04:14 PM
