Mopar Forums (/forums/)
-   -   84 D100 225 Slant Six problems (https://moparforums.com/forums/f7/84-d100-225-slant-six-problems-7687/)
cmetzbower Oct 5, 2010 03:31 PM
Hey, I have a 84 225 Slant Six with the stock one bbl carb. The engine will run ok for about 2mins and then wont idle unless I'm feeding it fuel OR it will idle ok but it has zero power and when I start to give it gas it starts to rev up but the quickly acts like its going to bog down an die (when it does that it won't run unless i have the air cleaner on and tightened down). I've replaced the fuel pump, fuel filter, fuel lines (about a year ago), pcv valve, pcv filter canister, and rebuilt the carb about a year ago. the vacuum pump is working correctly (i tested that from a line coming off the carb). Any help would be most appreciated. by the way the replacements or rebuilds were because of this problem and because the thing get 8-12mpg.
1966sportfury Oct 5, 2010 07:10 PM
have you checked for vacuum leaks?
78D200 Oct 6, 2010 02:32 AM
X2 on the vacuum leak. Have you given it a tune up as well?
mr.power Oct 6, 2010 10:40 AM
try the filter again
Minnesota Guy Oct 6, 2010 12:00 PM
Did it do this before you rebuilt the carb? "1 year ago"?..How many miles on the motor?
cmetzbower Oct 7, 2010 08:24 AM
It has over 120,000mi on it and it was doing it before the carb rebuild. I haven't driven it much after rebuilding the carb since I was away in the military but it was having the same prob before the fuel filter replacement.
78D200 Oct 7, 2010 10:45 AM
Inspect all the vacuum lines. Any cracks, even the smallest ones, replace the line.
cmetzbower Oct 7, 2010 02:35 PM
I've been looking for leaks and cracked vacuum line and so far haven't found anything. Any idea's? maybe a leak between cylinders? it also seems to blow oil into the air cleaner.
78D200 Oct 8, 2010 02:56 AM
Are you sure that you have teh right PCV valve?
Alos, if you are blowing oil into the air filter, you may have blow-by around a piston ring or valve. What does the compression look like across all of the cylinders?
Polaradude Oct 8, 2010 03:24 AM
Leak down test is your friend.
cmetzbower Oct 11, 2010 12:27 AM
ok, compression is normal not great but enough. I'm about to just rebuild the entire engine.
