87 Grand Fury Carb?
87 Grand Fury Carb?
I was just given a 60,000 miles Grand Fury not a spec of dirt anywhere on the car but like all lean burn engines it just doesnt like to run. So i have ordered the mopar electronic conversion kit for it and am removing all the lean burn crap but I am stuck on what 2bbl carb to get? I know I have to get one with a vacuum advance port but what model years should I be looking for?
Hi,
the carb you have is a model 6280 computer controlled carb
if you can find a model 2280 from a 1979 or earlier it will bolt up the same and not be computer controlled
Thanks
Thanks
wow trying to find that carb is almost impossible will something else work lol thanks for the part number i owe you a cold one now i just have to fine one!
In that case I would go with weiand intake part # 8022
and carb part # 0-80570 (570 Street Avenger)
This set up will work real good for you
And the carb has a life time warranty
Thanks
Thanks
