904 passing gear?
904 passing gear?
i have a 904 auto trans in my 73 duster 360, my passing gear isnt working so i did all of my adjustments and everything seems to be moving to full length at both trans and carb, my trans was out and flipped over at one time and with pan off is there a part in the trans that could of got unhooked or even just came loose that i can check, if so how do i check it and fix? thanks
Guest
Posts: n/a
More importantly why do you have a 904 in a 360 duster? That is just asking for it to get torn to shreds. The 904 was only supposed to be for the /6 and the 318 as far as I am aware. you should have a 727 in it.
I am not aware of anything internally, I am assuming you are talking about the Kick down linkage. It actually just grips the belt to the drum to downshift. You may want to check and see if it is securly attached to the tranny. I am not a transmission expert, But i did tear down my 727(just a big 904) and I cannot think of a reason why the kickdown wouldn't work internally unless your band is too loose or going bad.
Like i said before I am not an expert, but if it were me and I exhausted every resource I had (have you looked at the local library for books on the 904?), I would take it to a local tranny shop with an old guy that knows his stuff. when i put my interceptor transmission in my charger I had one of those guys do it and he did an amazing job with it for only $30.
Oh and if you wanna look at upgrading, i have a 727 that bolts up to a 304 and a case from a small block mopar transmission that i can sell you for cheap :-D I was told It was rebuilt less than 5,000 miles and operational when it was taken out of the jeep, BUT we have all heard that story before. Let me know
1337du0
13
Apr 17, 2014 06:17 AM
