9o4
Guest
Posts: n/a
9o4
hi guys,i have a 904 in my plymouth with like 4000 miles on a rebuild,the other day it started to slip when i torque it up on the brakes and shudders when shifting into 2nd.can i just tighten the bands to fix this? i have no knowledge of these trannys
i would make sure that your converter is ok first as with only 4000 miles on it, it should last way longer then that even with alot of power in front of it unless some one didn't do it right but have someone check your converter first and check your transfilter as it could just be pluged with band shavings from being just rebuilt
for only having 4000 on it im sure its your filter or even the converter but lets hope its your filter , just drop the pan and see what all is in the bottom of the pan and see if its full of shavings if so just clean it out good and change the filter , usually after you get a trans rebuilt you should always change the filter about every 2000 for the first time cause the shoes are like brake pads , they wear till they get conditioned
and the shavings have to go some where but not everyone does it and they end up burning the new trans out
