adding '302 heads to a 318 motor ???
Guest
Posts: n/a
i just joined, and its my first post, so be nice
ive been doing a little research on raising the power of my two door '77 chrysler lebaron. it has the factory 318 with the 904 transmission.
currently i have:
`long tube headers (summit)
`dual exhaust (2.5" with flowmasters)
`weiand action plus dual plane intake
`MP electronic ignition conversion kit
`holley 4160 4bbl in a 600 cfm size (yes, i know its WAY to big, i didnt know about VE when i ordered it
i have a set of '302 casting heads i pulled from the junkyard, and id like to put those onto it to raise the compression a bit, being that they are of a closed chamber/heart shaped design.
when i install these heads im also going to be going with a cam/lifter/valve spring upgrade as well (one of the kits from mancini racing)
id like to rebuild the heads, so i was thinking of getting 2.02/ 1.60 valves installed at this time as well as trying my hand at porting the heads a little too.
here are my questions:
would i need to change the pushrod length at all if i decided to deck the heads further to raise the compression even more?
whats the max you can go with milling the heads without having to get new pushrods?
with the raise in compression ratio, the carb that i have should be ok right?
what mopar perf. cam should i go with on this?
thanks for the help in advance
-glen
currently i have:
-glen
I can't help you out with the other stuff, but about the cam. what type of drive are you going to be doing? Do you have a stall convertor or a regular convertor in the tranny? That will make a difference when choicing the right cam.
I am basiclly going for the same setup as you with the exhaust, intake, carb and ignition, except I'm building a 78 d200 with a reman long block. Are you running an electric choke or manual on your carb?
Guest
Posts: n/a
right now im using the factor torque converter, but i do plan on upgrading that in the future
im running a manual choke on the carb
thanks
-glen
I would go onto summit racing and take alook to see what they have for that type of driving and look at the RPM range of the cams. Thats what I did and it took me about 3 days before I finailly decided on one.
302 heads on my 340 block
i checked my casing # 4838302----->does this mean fast burn,swirl,heart shape design......i dont ming grinding...if I PORT MATCH THESE WITH 340 GASKETS,UPGRADE THE VALVES....WILL I BE GOOD WITH FLOW. MY 340 BLOCK PURCHASE CAME WITH TRW.30 OVER PISTONS.....ASSUMING I DONT NEED TO BORE, I WILL USE THESE PISTONS.
We put this cam in one of our 318's great pull and purrs like a kitten.
http://www.compcams.com/Company/CC/c...ookieSupport=1 Changed springs with their recommendation. They have a program called Camquest 6, plug in your combo
and it gives you cam recommendations. The 302's will give you .5-.75 comp
increase. Do not put the 2.02" valve in the 318, the smaller bore shrouds the valve
(edge of valve to close to cylinder wall not allowing air to pass by) 1.88"+1.60"
are a great improvement. Your 600cfm size is bang on, I like vacum secondaries for
automatics. If you go with more than .450" lift on any 318 head have guide to retainer clearance checked. These engines can make loads of power in the upper
RPM's with a bigger cam but you will need higher number rear gears to take advantage of it. If you over cam these engines with lower number gears it will
be a mutt out of the hole. Trust me on this one. It's all about port velocity with
318's.
318's.
74Runneer
Sep 28, 2021 09:59 AM
gearheadmike
Sep 15, 2011 06:45 AM
