ASD relay 12v power fails to reach Ignition Coil
Old Mar 28, 2021 | 06:53 AM
stilllearning6's Avatar
1989 Dynasty 3.0L:
The ASD correctly receives 12v from both the signal switching source ( double white wire 12v supply from ignition key) and the constant 12v battery source ( double grey 12v from battery wires). See photo.
The ASD does correctly send power out of slave terminal green wire to the ignition coil positive (+) when slave circuit is triggered by ASD's internal primary circuit coil.
All good.
But, ... the ignition coil (+) terminal fails to light up my 12v test light that has probe at ignition coil positive terminal and other end gets grounded @ battery negative post.
I have not disconnected the green wire that should deliver power to the positive coil to test it separately , Do that tomorrow , better weather.
Perhaps this must be done to isolate why 12v is not sparking the coil.
Where does the green wire go after it leaves the ASD relay?
Perhaps a connection is corroded or green wire 12v is shorting ?
ASD Relay: white is 12v from ignition key switch, grey is 12v from constant battery positive supply, green will correctly send out 12v when commanded , blue/pink is ground for signal switch . All appears to work correctly.
stilllearning6
Mar 28, 2021 07:19 AM
rhoole93
Apr 8, 2020 04:31 AM
stilllearning6
Jan 11, 2018 06:47 PM
ssdart225
Feb 25, 2011 05:18 PM
volare79
May 17, 2009 04:36 PM
