cam
Old Apr 9, 2013 | 03:46 PM
goldenpistol's Avatar
cam
higuys looking for cam shaft for my engine mopar 440 with rpm performance dual palne intake rpm range 1500 to 6500 and stealth cylinder heads intake port 212cc intake valve head 2.14 exh 1.81 with 80cc close chamber and speed pro pistons flat tappet part zl2355f40 with converter stall 2200 to 2800 gear ratio 3.55 compression 9.8.1 im looking for street/strip cam shaft hyraulic roller with timing chain and lefters with smooth idle
any brand but good one if lunati or comp need part number for each cam and timing chain and lefters if psossible
Thanks
Old Apr 9, 2013 | 04:07 PM
jacilynn_s's Avatar
did you look in the mopar performance catalog at the numbers? Its a good reference as it gives the information your looking for.
deadkelly
Aug 30, 2009 07:24 PM
bad_karma
Aug 28, 2008 02:03 PM
djg1978
May 3, 2008 03:53 PM
JuhKiv83
Nov 20, 2007 07:19 AM
bcuda65
Apr 26, 2007 04:38 PM
