Car Maintenance
Car Maintenance
Cars need best maintenance throughout the year, particularly in hot summer and cold winter. Here are top ten summer maintenance tips that will help you keep your car in good condition-
1. Now you need to undo all the process you have done for winter storing. Remove your snow tires, give your car a good water cleaning service.
2. Check your tire pressure regularly
3. Test your oil, especially before you go on a long trip.
4. Make sure that all the belts and hoses are solidly attached.
5. Check the air filter properly since it may be clogged.
6. Your brakes are perhaps the most important part, it requires good maintenance.
7. Check the battery regularly. Also ensure certain connections are clean and the cables are firmly attached.
8. Replace all of your coolant at least once in every two years.
9. Have your air conditioning checked at the beginning of summer.
10. Replace your windshield wipers if they look worn out
If you have any queries log on to Carcovers.com
mystarcollectorcar.com
Aug 8, 2012 08:35 PM
rcknrolfender79
Sep 12, 2010 01:38 PM
Aug 20, 2010 01:33 AM
Moparknighthawk
May 22, 2010 09:10 PM
