Car not getting spark.
Old May 31, 2010 | 11:06 AM
sgnrulz's Avatar
Alright.
I'm really out of ideas.
Previous owner upgraded it to electronic ignition.
I have power to my coil. Coil is new. Coil is sending spark to distributor.
But it isn't getting to the plugs.
Distributor isn't cracked. Nothing is excessively worn down or corroded.
Quite stumped. Anyone got an idea?
Old May 31, 2010 | 11:55 AM
re-trace all the wires going into the wiring harness
Old May 31, 2010 | 12:06 PM
ef8340's Avatar
Senior Member
is the rotor button on?
Old May 31, 2010 | 12:44 PM
blue 68 gts's Avatar
Do you have an actual mopar electronic dist? Or just a normal one where you have to splice the wires into it? If you have option 2, get rid of it, and get a mopar electronic dist from O'reillys, craigslist, autozone, ect.
Pull the cap off, check to see if the pick up is chewed up. Mine did that.
Old May 31, 2010 | 02:03 PM
sgnrulz's Avatar
The clamp was slightly corroded. distributor wasn't getting ground. I now have spark.
Fun fact.
My fuel pump also decided to go out at the same time.
Never a dull moment.
Old May 31, 2010 | 04:13 PM
Sgt. Veteran's Avatar
Old As Dirt
muffler will fall off next if I'm reading these tea leaves right ....
Old May 31, 2010 | 06:58 PM
sweeperking's Avatar
This is a good question because if you have spark from the coil that leaves the distributor cap, rotor, plug wires, and/or plugs at fault.
Old May 31, 2010 | 06:59 PM
Fun fact.
Old Jun 1, 2010 | 01:24 PM
sgnrulz's Avatar
Thanks for the heads up.
haha
Old Jun 1, 2010 | 05:04 PM
Old As Dirt
left side by the way lol....
Old Jun 3, 2010 | 06:49 PM
scotts74birds's Avatar
"Novelty" coil wire?
Old Jun 3, 2010 | 08:13 PM
Either that or maybe magic
Old Jun 4, 2010 | 02:41 AM
Polaradude's Avatar
Hey Von Doom, where ya been ?
Old Jun 5, 2010 | 08:06 PM
Temporarily "pulled-the-pin" on the domestic situation. Came back. One week later,.....same old ****. A lifestyle change is in the works bro!
buttton
Apr 1, 2013 10:00 AM
Duster360
Nov 14, 2012 05:40 AM
austin
Sep 18, 2012 12:37 PM
mannygman
Nov 26, 2010 02:14 PM
