Changing oil and fluids
Old Dec 9, 2011 | 04:41 PM
AnthonyGW0114's Avatar
I got a 1978 Dodge D-150 Macho PowerWagon and i'm curious about what kind of oil weight i should use. Also i'm planning on changing the tranny fluid along with the differential fluids so i'm mostly curious as to what lube as to 80-90 or should i use something else. And the same thing goes with the transfer case. Anyways if you can let me know or help me out that would be much appreciated.
Old Dec 9, 2011 | 05:23 PM
78doubleR's Avatar
im assuming 4speed since your suggesting thicker oils. if so put lucas 75w-90 full synthetic in the trans and rear end. wont have to change it for a long time that way.
I'm not sure on what t-cases use though. someone else will chime in on that.
sm73charger
Feb 13, 2011 11:20 AM
dzltd02
Oct 28, 2008 08:25 AM
mukky
Aug 7, 2008 09:39 PM
robertoil
Jan 25, 2008 05:34 PM
