Charger not charging
Guest
Posts: n/a
Hi I have a 69 Charger that has decide not to charge. I have replaced the regulator, and alternator, the battery is good. I have been trying to trace the wires back to check the wiring and make sure everything is hooked up. I appear to have it hooked up properly but it won't charge. I am stumped. Thanks
Guest
Posts: n/a
Russtoy now charges
Hi guys I figured out the problem of my 69 Charger now charging. 1 the new alternator did not work, 2 I found some wires that were cracked and broken. I did find a very helpful response on this forum, that I followed,
that pointed out where I should start to look. Thanks
