Crosspost: 440 Oil cooler questions
Old Feb 15, 2014 | 09:41 AM
70chargerAZ's Avatar
Question Crosspost: 440 Oil cooler questions
I think I originally posted this in the wrong section, so here it is again.
I'm building a 440-to-543 stroker. I'll leave the bulk of the build's information out of this topic for the moment.
I plan on installing an oil cooler, but have never done really messed with oiling systems before. I'm running an aftermarket, external oiling system by either Milodon or Melling, and had some questions:
1. I've seen oil coolers run off of a filter adapter, is this really the optimal set-up, or is there a better way?
2. Could I run an oil cooler off of the oil pump itself if I have the required fittings installed? (for example: from the oil pan pickup to oil cooler, then from the oil cooler back to the to oil pump?)
3. Does anyone make a kit in either of these configurations?
4. Is there anything I'm missing here?
70chargerAZ
13
Feb 16, 2014 07:43 AM
68lover
Apr 29, 2010 07:24 PM
dzltd02
Oct 28, 2008 08:25 AM
robertoil
Jan 25, 2008 05:34 PM
