Died now & won't start
Old 05-15-2008 | 09:51 PM
Time for back to basics.
First, you are running simple dual points and coil, no electronics, is that correct?
Do you have the ballast that the Accel recommends for the coil?
First, with the key on, and you need a voltmeter or lamp, measure from the coil neg. (dist side) to ground. bump the engine and see if you have 12 or not, as you bump the engine, or the light will light/ not light, as the points open and close.
If not, go to the "ign" side of the ballast, and you should see very close to battery voltage. When cranking, you should see probably 11V at least.
The coil side of the ballast will vary. If the points close, this voltage could be very low.
Have you tried pulling the coil wire, and either hooking it to an old plug, or holding close to the block? You should be able to crank and get a spark. Do this with a helper, using the key. If you do this using a remote switch, or by jumpering the start relay, you will not get "ign2" or resistor bypass, and the spark will be weak from low voltage.
Do you have an old used coil (good) that you can sub?
ALSO if the voltage checks are good, and the points are opening/ closing, a bad condenser (capacitor) will not "make" spark. The car will not run without a condenser.
azsportfury
12-08-2015 04:42 PM
Drew Barclay Cambridge
05-20-2013 04:55 AM
chykov's76doba
04-10-2013 06:11 PM
jbda
04-01-2013 10:22 AM
hayster1
01-23-2013 07:28 AM
Quick Reply: Died now & won't start
