Distributor leaking oil
Old Oct 27, 2010 | 02:08 PM
ChargerBoy'71's Avatar
Hey guys,
I pulled my distributor to clean it and ever since, it has been leaking oil to a point where it pours onto the exhaust manifold. I'm thinking its just a gasket, but are there any other possible causes?
Old Oct 27, 2010 | 04:04 PM
blue 68 gts's Avatar
If you're sure its coming from the Distributor, then its just the O-ring
Old Oct 27, 2010 | 04:37 PM
ok thanks
Old Oct 27, 2010 | 05:11 PM
scotts74birds's Avatar
You are losing timing fluid. Loose too much, and you may become retarded!
Old Oct 27, 2010 | 05:39 PM
I was going to say bad stuff, then I saw your name next to your post. LOL
Old Oct 27, 2010 | 06:07 PM
so its the gasket or the O-ring?
Old Oct 27, 2010 | 07:05 PM
rr69half6bbl's Avatar
lmao, youll have to excuse scotty, hes just being scotty, actually you need both. the o-ring fits in a grooved slot under the bottom lp of the dist. then there a paper gasket that fits under the dist base when you put it down.
Old Oct 28, 2010 | 01:48 PM
are you a big block?
if i remember correctly, there is no extra gasket, just the o-ring that is on the distributor
either that is bad, or your PCV and breathers are clogged, so the high pressure in the engine is forcing the oil out of the distributor, or the bushings in the distributor are worn out, and the o-ring cant hold back all the oil that is making its way up to it
Old Oct 28, 2010 | 04:10 PM
small block. i re-timed the engine when i replaced the intake, but i dont remember any mounting gasket. Thats most likely the problem.
Old Oct 28, 2010 | 05:52 PM
teh gasket just sits undr the dist. base. its a secondary sealfor it and sets between the block and dist. where as the o-ring seals in the block ,not on top.
DusterDude88
Sep 9, 2012 09:42 AM
ChargerBoy'71
Oct 11, 2010 06:45 PM
jtvisco
Nov 8, 2009 03:38 PM
wrenchn365
Oct 8, 2009 01:20 PM
dzltd02
Oct 28, 2008 08:25 AM
