Distributor points gap for 318
Hi, can you please tell me what the gap spec is for the points on my 1966 Plymouth Fury sedan with a 318 motor? This will obviously tell me what "feeler gauge" to use.
Thank you very much.
I NEVER used to set points by gap, and in fact rarely used a feeler. Just eyeball them to start, and use a dwell meter. Set the dwell "rough" "on the starter." Then pop the cap on and start the engine and recheck the dwell. It might change. Note that, and reset if necessary.
Always set them towards the "open" side and recheck after 500 miles. They "wear in." For dwell, this is the smaller of the dwell number, lean towards 28 rather than 32.
Put a tiny tiny tiny, did I mention "little bit" of high temp lube on the approach side of the rubbing block. Better quality points "used to" come with a capsule of lube.
Thanks
Hey!
Chrome
i all ways found it helpful to be sure the the point seat flat to each other. then set the gap at .015. useing the highest lobes only. i was all ways able to get the duel point big blocks to come in at 42 dwell angle. before i checked it with the meter.
