flex plate?????
Old Jan 18, 2011 | 10:29 AM
bentman's Avatar
flex plate?????
I put a internally balanced 408 in my 73RR & had to buy a new T/C because it had weights on it. Do I need to buy a new flex plate?
Old Jan 18, 2011 | 11:01 AM
MercuryDon's Avatar
No on the flex plate. If the engine was not balanced with the damper on and it was a exterally ballanced damper you will need to replace it also.
Old Jan 18, 2011 | 11:53 AM
bentman's Avatar
I'm confused some people say I need a new flexplate & some say I don't.
B&M says I need 1
Old Jan 18, 2011 | 05:44 PM
1966sportfury's Avatar
A.K.A Bob Dodge
if it is internally balanced, you do not need a weighted flex plate or converter, if its externally balanced you will need a weighted flex plate or converter. if you put a weighted converter on a internally balanced engine, you will need to replace the bearings after start up., and probably a new tranny.
Old Jan 18, 2011 | 06:59 PM
Silverick's Avatar
The old flex plate should be fine. The weights are on the converter. You probably could have taken the weights off of the old converter and been fine.
68GTX440
Oct 1, 2013 06:25 PM
goldenpistol
Apr 22, 2013 07:57 PM
willysman69
Dec 23, 2011 01:25 PM
mytracy
Dec 29, 2010 08:20 PM
mikeynags
May 3, 2010 06:45 AM
