Fram Oil Filter
Old Dec 23, 2008 | 05:53 PM
Commando's Avatar
Fram Oil Filter
Anyone know the part number for this Fram filter that 440 source is selling as a higher capacity model: http://www.440source.com/oilpumps.htm
Old Dec 23, 2008 | 06:01 PM
challenger's Avatar
i do not know the number but im pretty sure its the fram racing filter you should be able to go to your parts store and tell them you want the racing filter by fram and they should be able to come up with the #s
Old Dec 23, 2008 | 09:36 PM
Would pound pump are you gonnna put on your car?
Old Dec 24, 2008 | 05:32 AM
Commando's Avatar
I got the Melling high volume one, not sure on the specs.
I will check out the race one, I want the number so I can get the Wix equivalent, as I have heard countless times about how bad Fram is or how much better Wix is.
Old Dec 24, 2008 | 06:13 AM
I have heard this too, but never had problems with fram. But, top be safe, I just run purilator now.
Old Dec 24, 2008 | 07:27 AM
smackhonda's Avatar
The reason fram boost oil pressure is because it filters down to a smaller micron. That means it is filtering more dirt out of your oil which is better. Them small micron particles of dirt is what does most of the damage to your bearings. As long as your oil pressure isn't running up above 90 you should be fine.
Old Dec 24, 2008 | 12:44 PM
Commando's Avatar
I found it in Wix if anyone is interested the standard filter is a 51068 and the larger one is a 51515.
Recoil77
Apr 10, 2011 01:33 PM
Demonized
Jun 23, 2010 10:39 AM
mikeynags
Jun 26, 2009 08:42 PM
theomahamoparguy
Mar 30, 2009 05:31 AM
dzltd02
Oct 28, 2008 08:25 AM
