fuel pump priming?
Old Oct 2, 2009 | 03:43 AM
Polaradude's Avatar
If you have a mechanical pump now and the lines, filter etc are good and the pump itself is good it should deliver fuel right away.
Old Oct 2, 2009 | 05:04 AM
MrOldart2U's Avatar
Post
If you had it running for 5 minutes by misting/spraying fuel into carb yes the pump should of 'picked up' the fuel. Only thing it can be no fuel in tank, or bad pump. If there is a pre-pump filter it could also be plugged....
Old Oct 3, 2009 | 08:49 AM
the fuel pump only needs a few seconds to really prime itself
i would check over your fuel lines, change gas filter
and check your timing
it could be so off that the car just wont start
raycan2
Aug 15, 2013 08:22 PM
chykov's76doba
Mar 25, 2013 09:58 AM
mopars&vampires
Jun 23, 2009 09:31 PM
skymynx
Oct 21, 2008 07:15 AM
rapidride2
Mar 20, 2007 05:58 PM
