Gas to use?
Leaded / Premium 93+
Nowadays, there so many additives to our gasoline to make fuel mileage "better". It's aimed at cars that get higher miles per gallon, as compared to our old rides, and older trucks.
Back in the day everything was leaded.... now a day, lead will mess up the computer readings... Non leaded gas doesn't have a high enough octane rating and will cause pinging
I ran my 74 J10 on 87 with no issues minus with the guy driving it.
I ran my 78 D200 on 87 as well with great results minus with the guy driving it.
Now with my 68 Valiant, I run that on 87 (might through a tank of 91 into though) and it too runs great, minus the guy that owns it.
There seems to be a common "opportunity for improvement" there.
http://www.sunocoinc.com/site/Consum...UnleadedFuels/
The Octane Rating has to do with the fuels propensity to auto-ignite. The lower the octane rating, the greater the chance of the fuel auto-igniting under high compression. This is what causes the pinging. The fuel ignites before the spark plug fires.
That is a false statement. Leaded/Unleaded has nothing to do with Octane Rating. I worked at a gas station in the late Eighties and we sold 89 Octane Leaded. See this link for High Octane Unleaded Fuels:
can i give my 2cents? 85 octane has a higher btu burn rate per gallon than 92, 92 burns cooler but producess a higher "explosion" (do i dare say) too high of octane can actually hinder power,
You shouldn't run a higher octane than your motor is rated for. My '07 Charger R/T is rated for 89 Octane. If I run anything higher the car runs a little sluggish. I can reprogram my car for a "91 tune" which would advance the timing necessitating a higher octane. It's not the higher octane that gives me more power, it's the timing advance. The higher octane is needed to prevent detonation.
Foedoe
Mar 8, 2011 07:47 AM
