GTX runs roughly and dies
Old Oct 6, 2021 | 11:14 AM
gtx-'s Avatar
Hi guys,
Currently i’m troubleshouting a Pymouth GTX from 1968, the car is running and driving smooth for 30 seconds. after that the engines runs so rough that it will shutdown itself.
The first thing I have tested was the battery and tried my second battery, booth were fine, then I noticed while running the engine, the battery I not charging at all.
Unplugged all the wires, cleaned small corrosion and checked all the fuses, that should be ok now, but was not the problem.
I have tested all the ground wires, smoothed them up, but they were still ok.
Then the alternator came to my mind, checked all the belts (new) and don’t seem to be that tight, started the engine, checked if the pully from the alternator is spinning, it did. After that step I with the multimeter the alternator here are the results:
(Off)Battery 13.3 V
(Running) Battery 12.5V (not charging)
(Off)Alternator 11.7 V
(Running) flipping between 0 V and 9,5 V very fast
I could not test the other 2 wires on the alternator because the wires from multimeter were not long enough.
Any thoughts? Maybe the volt-regulator or seems clear that the alternator is death..?
Old Oct 7, 2021 | 07:39 AM
Here you go.....
Old Oct 7, 2021 | 02:37 PM
Archer's Avatar
gtx -
Sounds more like fuel than electrical to me.
Crimp in line, clogged filter, carb needle/seat, etc.
arrows
Mar 5, 2021 01:49 PM
64Imperial
Oct 3, 2016 09:56 PM
josehf34
Feb 22, 2014 09:25 AM
SixtySevenDodge
Apr 9, 2009 08:15 PM
