HELP 318 BACKFIRE PROBLEM
I have an 85 chrysler fith avenue with the 318 in it and a 2 bbl carb. It has 86000 miles on it. When i first got it it seemed like it was firing wierd in the number 4 cylinder. i changed all of the plugs and found this one to be rather black compared to the other ones. then about a week later it started again. i was told it was probably the lean burn so i got an electronic ignition kit from summitracing. this didnt seem to help it even with the timing set correctly, new plugs,new wires, and a new coil. it didnt seem to be that much of a problem so i went ahead and put my headers on. now it is very noticible. it seems like the one cylinder isnt firing right. when i let off the throttle it backfires horribly out the one side, when i give it light throttle it hesitates and is very sluggish and sometimes stalls. please help me.
Welcome to the forum.
If you have a spark tester install that between your wire and spark plug. Start up the motor and see how bright the light is. Turn off the vehicle and install the spark tester on another cylinder. Repeat the process.
If there is no difference in brightness, remove the plug from cylinder 4 and do a compression check. While you are at it, swap that plug with on on the other side, maybe 5 or 7, start up the vehicle and see if the problem goes to that cylinder. If it does, then its probably just the plug. If you have bad compression, you'll have to find out why.
Hope this helps some.
No i have not checked the compression yet. i was hoping that wasnt the case as i dont want to rebuild or change the motor right now. i did find a 360 with a trans and a transfer case for 200 bucks with 70000 miles on it i may just get that and put it in. any idea if i would have to change anything. i know i need to use the torque converter from the 360 but im not sure if i can use it on the stock chassis. im assuming that the tranny out of the jeep probly isnt geared that great.
you have a two drive car and that is a 4wd drivetrain. That motor is probably a magnum and you have a non-magnum motor. Look to see what is going on with your motor first. It may be a simple fix or a lot less costly repair than buying a motor ans swapping it in.
Hopefully you did not buy that motor. The V8 motors in the FSJs (Full Size Jeep) are not Mopars, they are AMC, completely different motor and will not just bolt right in.
Tranny will probably be a TH400 and the t-case will most likely be a D20 as the QT t-cases didn't come out til 74.
i did a compression test and i have approximately 120lbs in all 8 cylinders witha 5 lb deviation range. so i do not believe i need the motor. Im starting to think its the valves or the cam or something
if it was the valves or cam then you would have a pressure deveation of a lot more than 5. Move the spark plug from that problem cylinder to another and see if the problem goes with it. Are you sure that you are getting good spark? Can you see down into the chamber?
It could be the lean burn system that is the problem.
I put brand new plugs in it already after it happened. everything in the ignition system is brand new coil, wires, distributor, cap and rotor, plugs, wiring, ecu. its sparking fine it just still backfires out the one side.
Guest
Posts: n/a
a leak down test is a test to see how much blow by "leak" your rings are letting by. too see if the rings have any tension, or... if valves are burnt/seating properlly, if the valves are bad you will hear a popping when you let off the throttle....or its a hole in the exhaust system, when you replaced the ignition what did you replace? those years you need too up grade to a vaccum advance atleast, and get rid of of the aircleaner computer get a non computer controlled 2bbl. and a after market "brain" msd-mallory-pertonics or old points...so on..
A leakdown test is when you put say 110 psi in each cylinder with an air compressor. The hole you are testing must be on a compression stroke with both valves closed. ( engine is not running ). Once that cyl. is pressurized I take a short length of fuel line and I listen with it like a stethoscope. First I listen to the carb,inside the bore. If you hear alot of air you know you have intake valve probs. Than i listen to the dipstick tube and the oil filler cap, If you hear alot of air there you know you have ring probs. Than I listen to the exhaust pipe/s. If you hear alot of air there, exhaust valve problems.
I made my air fitting from an old spark plug that fits the engine you are working on, just knock off the ceramic and get a hole through the old plug so air will flow and put a airline fitting on it. Thats the broad strokes on a leak down test.
when i replaced the ignition i used the electronic ignition conversion from summit. it came with the ecu, and the vaccum advance distributor but every piece of the ignition system is brand new and i had it checked out by a few people to make sure it was done right.
your prob
pull the valve covers. check all the rockers. chances are you have a push rod threw one. it mite be a back one, on exoust side. if thats the case put new push rods, cam and lifters. i just had the same thing happen to my 88.
dodgeaspenrookie
07-23-2012 12:15 PM
alan_01_uk
05-08-2009 11:53 AM
