help with car stalling
OK so i just finished installing my transgo shift kit and now whenever i start my car and shift it from P or N to D or R the car stalls out and just keeps doing it and if i can get it moving each time i go to a stop sign or traffic light the car stalls out. im thinking maybe when i installed the shift kit maybe my transmission throttle linkage might be out of wack causing it to stall and such. is this a possible cause for my problem if so whats the best way to adjust it.
thanks a lot
mike
P.S. i have a 1978 chrysler cordoba with a 360 2 bbl and a torqueflite 727 trans.
thanks a lot
mike
UPDATE: OK i made it so when in neutral/park she idles at about 1000rpm then when i put it in drive it drops to about 4 maybe 500rpm and drives, but if i try to put it in reverse the car stalls out, any one know what maybe happening or how to turn the rpm up for drive/reverse?
thanks a lot
mike
thanks a lot
mike
did you unhook any vacuum lines when you installed the kit , take your breather off and when you put it in gear listen to see if it hisses from the carb from a high hiss to low when it stalls / cant remember but did you do it while the trans was in or out of the car ?
Don't think so.
try spraying some water on the hoses and see if it changes the tune of your engine, to me it sounds like a vacuum leak some where, you can use carb cleaner but you have to make sure you dont aim it at any spark (NO AIMING IT AT ANY SPARK)
the water trick works wonders with a vacuum leak. Did you play around with the kick down cable at all? Also, are you sure that you adjusted the band properly? Not saying you don't know what you are doing, just asking though.
i hate not having my car up all the gears are working except reverse whenever i put it into R the car stalls out, then every now and then if i quick put it in R and give it some gas it will keep the car alive and work but that's like 1 out of 100 times. can that be vacuum related or what?
Tighten band adjusting screw to 72-inch lbs. and back off 2-1/2 turns. Tighten jam nut securely. (I always used 6 ft/lbs, or as close to that as I could get it since I don't have a torque wrench that measures in/lbs. This should put you very close)
is this for the front and rear band?
That's going to be up to you. I normally use Ford Mercon stuff, just cause it's a little heavier, and causes slightly tighter shifts. I think it calls for Dexron from the factory. (and I'll even admit to occasionally adding about 1/2 quart of 30 wt motor oil... ) I'm not a professional, this is just stuff that's worked for me over the years.
so i should just tighten the adjusting screw to about 6ftlbs then back it off the 2 1/2 turns?
