help me find a carb
Old Apr 16, 2009 | 08:38 PM
78cordoba's Avatar
Member
help me find a carb
OK so i need some guidance on what carb i can use on my Cordoba, i have a 78 Chrysler Cordoba with a 360 and a 2 barrel carborator right now and i want to upgrade to a 4 barrel carb, but i dont know what i should be looking for. so if you guys can help me with getting a 4 barrel carb and an intake manifold, im thinking about looking for some when i go to swap meets and such
thanks a lot
mike
Old Apr 16, 2009 | 09:00 PM
scotts74birds's Avatar
Hey Mike, There was a time I would suggest a holly or a demon carb. But lately both of these things have been driving me insane. If you have a stock motor and plan on nothing more than a 4bbl and dual exhaust for cruising,I would suggest a factory intake and carb. Or maybe a performer intake with a stock or aftermarket carb with a 650vac secondary. Be forewarned, if you go aftermarket on the carb ther will be issues of fuel fittings, choke, linkage, kickdown lever, fuel pressure, and the hair pulling process of dialing it in. I'm totally frustrated with my carb now. Save yourself! Good luck
Old Apr 17, 2009 | 06:30 AM
craveman's Avatar
Senior Member
what 2bbl do you have on it?
Old Apr 17, 2009 | 06:32 AM
craveman's Avatar
Senior Member
i have a 4bbl #6231 from a 79 motorhome with a 413 on my 318 that i will be pulling this weekend to put a 2bbl back on the 4bbl intake. i just liked the way the last 2bbl performed. the 6231 was a bit too big for my engine but would probably be ok on a 360. it needs a rebuild and has no choke but if your interested pm me
Old Apr 17, 2009 | 11:31 AM
72RDRNR's Avatar
for a good cruiser and the occasional drag I like edelbrock/carter. nothing to them so easy to tune and keep running. also if you are up for doing a rebuild you can pick them up cheap.
Old Apr 17, 2009 | 04:52 PM
theomahamoparguy's Avatar
I like the edelbrock that is designed like the old Carter-AVS. Also, you can get adapters for the mopar linkage for either a holley or an edelbrock.
northcoasttip
Sep 26, 2011 11:23 PM
Jim Smith
Jan 9, 2011 04:16 PM
1923tbucket
Oct 26, 2010 07:14 AM
mopar nate
Feb 6, 2009 09:19 PM
