holley 6231 questions
Senior Member
on
i was looking in an old motorhome today at a junkyard to see what motor it had in it. i found out it has a 413 in it. the carb on the engine is a holley 6231 and appears to be in need of a rebuild but in good shape. i squirted some wd40 in the fuel lines and moved the throttle and it leaked pretty bad. while i was looking around in the cabinets and stuff i found a holley 6231 reman brand new in the box. i was just wondering if anyone knew any information about this carburetor. it does have small primaries on it and seems like they are either the same size or maybe slightly bigger than the secondary bbls. seems like it would be a good carb for torque but i was wondering if anyone knew an approximate flow rate for this carburetor. i picked it up anyways cause if it wont work on my car or my truck i can always ebay it.
